Okay, I changed the battery the other morning, as the old one was shot to pieces and wouldnt even run the radio.
My micra is now doing all sorts of weird things. Such as the 'malfunction' light come on. I looked in the manual, and apparently this is something to do with NATS.
Whatever it is, it's stopping the use of the speedo, indicators, and this annoying flashing yellow malfunction light.
In the manual it says the only thing that can solve this is for the car to be taken to a Nissan dealer. I obviously want to avoid this if possible, due to expense and that there isn't exactly one local.
Is this a common problem with a simple repair solution? (please say yes!)
(Just a side note, when replacing the battery, I did accidently touch the positive to the negative and the negative to the positive, but only for a fraction of a second)
The car does, however, start and idle, which means there is nothing wrong with the alternator, as i'm reliably informed.
PLEASE HELP!!
PLEASE HELP!!
