HELP!! Water leak from radiator!
I've got an almera radiator on my k11.. Theres a leak because it's catching the alternator on the engine... Anyone know what other radiators would sit in a micra without any modifications. I've tried a civic rad but no luck. All help appreciated :) thanks guys
why not use another rad the same as yours! and then mount it bit furthur forward! taking into account the movement of the engine? that seems to be the hassle free method in my head
It does fit but it catches on the alternator which then ends up slowly making a hole and then eventually a water leak.. Ive change the rad 3 times and also tried a GA radiator of a 1.5 almera
