help! trying to lower rear!
Gone with the matiz setup on front and worked a treat. Don't want to cut any springs for the back though! Any other ways of lowering back 50mm without cutting. Help is much appreciated!
my 05 matiz rear springs have dropped the rear 50+mm ash, i had to fit the rubber seats at the top tho (the springs were chafing the top perch slightly)
you will need the shorter corsa shocks tho :)
I got corsa shock but they didnt fit. the bottom of the shock where the bolt goes through is smaller than it is on the micra.
most of us just fit the smaller m10 bolt ash, you would need progressive springs if you wanted to retain the stock shocks
Yep...I can agree they are fine....cut 2 1 /2 springs off mine with corsa shocks been running for a month ...all hunky dory...;)
sent using the send button. .....
Fitted matiz rears but only gave around a 30mm drop. Gona go breakers and get 05 matiz rear and see how they do with corsa shocks. Thanks for help guys!
