help please with ground connection
I replace my engine and now I dodnt remember were this ground connect to.
in the place were the possitive cable go? I have to unscrew a bolt and fit them there? also I can not found the clip to connect the liitle ground is on the motor too?
Sorry, I forget to post pictures for you so I will send it tonight. By the way, is your micra working now?
Took some pictures for you.
Black with yellow line wire will go on one of two top bolts of this gearbox.
Starter motor wires.
Small black plug
