Dipped Beam and Main Beam are the same bulb (H4,3 pin)
Remove the cover on the back of the headlight (if you've got one) pull out the plug. Theres a clip that goes around the bulb,you need to push it down (into the headlight) and pull it towards you. The clip then should slacken and you should be able to pull the bulb out
