fao for people with BC Coilovers
I need the top mount part number so I can fit my Gaz Coilovers as they don't come with top mounts and I need to do some camber adjustment on the fronts. I have a Nodspeed rear bar so the rear will be fine.
I don't think the camber plates and housing have any printed part # (only labelled left/right) nor are the camber plates sold separately.
they do sell the BC/BR series pillowball top mount bearing housings in the accessories section and you then fabricate or buy a camber plate to fit it.
http://www.bc-racing.co.uk/accessories/bc-br-series-black-top-mount-bearing-housing-front-1.html
Bugger I have tried looking for adjustable top mounts but I can't seem to find anyone that makes them, I saw your thread when you got your BCs and you de constructed them and the top mount came off so I thought you could buy them seperately. Thanks for the reply though.
Yea just spoken to Jason@Apex and he said the same thing as he doesn't want to order the them and then not being able to be returned, so I need to measure the diameter of the shock and he will measure the hole in the bearing. Also he mentioned that it will be the ones off of the BCs rather than the KSport ones as they don't supply the KSport suspension parts anymore as they weren't upto their standards.
Thats some nice machining :) is that what your basing it on or one that youve done?
Also what you making them on? :)
That one is for a Mk2 Escort but I plan to replicate it in a smaller form for the micra crowd :)
Lower section can be lathed. Upper section most likely water jet cnc'd
How are you making those? as they are exactly what I need. I didn't manage to measure my shocks as of yet as I have been busy with work and stuff.
BCs for micras are usually a 12mm shaft.
As above with the two machines depending on costs
Then I'll throw em into some OTT testing before I'd recommend them to others
You could cnc mill both sections, getting one company to do both parts could make it cheaper.
