C
Ciaran Costelloe
Guest
Left-hand headlight high & dip failed, changed bulb, tested bulb, dismantled & tested stalk switch: with a voltmeter across the bulb terminals but no bulb, I get 12V, but this disappears when I plug in bulb. So I reckon it's a broken wire (but copper still touching) or the dim/dip unit, a grey box buried up behind the dash (saw it in the wiring diagram, but I ended up removing the complete dash before I found it). From the wiring diagram, if I remove the unit and connect the terminal connectors 8 to 10 and 1 to 7, I will get a "normal" headlight wiring circuit.
This begs the question: what the **** does the dim/dip unit do? I cannot think of any useful function it might provide.
Ciaran
Ciaran
