Got a new set o clocks for the micra however it says 60oddk on the clocks and minty's only done bout 30k anyone no a surefire way of setting the new clocks numbers to match the only set
Mine have been altered, but they're the super s type, so it's possible. Not sure if you can adjust the other ones though. A drill will also work as mentioned above, but it will only go about 30 mph and take you all day!
arnold when you changed you mileage did you remove the pin the adjust them, i did and when i put the pin back the middle three numbers dont stay in place, so i cant use the dials yet.
