CVT error code 6
Hi
Done a CVT diagnostic test, I am getting Fault Code 6 - The sixth blink is on longer than the others - Torque signal circuit is short circuited or disconnected.
Can anyone tell me where the Engine control unit and CVT control unit, I want to see if any corroded terminals and check the continuity of the 12v to these units.
Cheers many thanks, out of interest are replacing these units, plug and play or is there software etc to loaded?
Depends if you have nats or not. If you have then you cant just replace the ecu. You might be able to swap the gearbox ecu but it wouldnt be something id suspect to be bad.
