conzult (trial version)
Ive got a conzult wire/plug and a disc with the trial version of conzult off ebay and just wondering what you can actually do with it? as all i can do with it is turn the cooling fan on and off. only thing that i can think of that it might be is that i am using a serial to usb conversion cable to connect it to my laptop
any help will be appreciated
ash
i think you can only monitor the settings with it ash, and any changes (timing etc) will revert when you turn the engine off iirc :grinning:
thanks frank, the problem is that i cant do anything at all with the software apart from turn the rad fan on and off
i think you can only alter the spark timing and idle control anyway ash, and the timing will revert apparently,
there are other software options tho are,nt there (solarice may know ?)
or baguete is probably the best one to ask
