im shure you need a 1.3 clutch for the box, i dont think the 1.6 fits but im not totaly shure, you can always upgrade to a stronger 1.3 clutch by helix if the oe clutch isn't lasting long with the 1.6 engine
online suppliers are showing different 1.6 clutches (almera, for instance, iirc are listed as 180mm/18 spline, and other model 1.6 ga,s are 190mm/18 spline)
different brands will have different springrates, and use different friction material (my exedy clutch slipped bad) matt would probably be your best man for advice
