Clutch disk replacement advice
800 euro,s seb :eek: your garages know how to charge eh
and yes the pre 98 1.0 uses that 160mm plate (Y)
and get that flywheel machined down to 4kg while the g/box is off :cool:
Thanks for the confirmation Frank, I knew you would answer ;)
So if I'm right, basically "machining flywheel" means "drilling clutch disk to lose weight (thanks google) is there a special holes layout to respect Frank?
that photos impressive frank might borrow it in another thread. frank isnt it a lot easier to install it with the lightened flywheel in traffic?
