The pas pump is bolted straight onto the block but there should be a pas/waterpump tensioner pulley just underneath. Remove right wheel n splash plate, loosen the pulley axle nut so it can slide up/down, screw the vertical tensioner rod clockwise to lower & loosen the pulley. Change belt n reassemble
