O
ohc_turbo
what are the diffrences between the 1.0 carb and the 1.2 carb, ive heard stories that they are the same and have heard another story saying that the 1.0 carb would be a upgrade if you were to swap it for a 1.2 carb.
not worried about the upgrade but can i put a 1.0 carb on a 1.2 engine and it will run fine.
apparently the jets are bigger on a 1.0? maybe cos the redline is higher than a 1.2 and thus it would have to support more flow at higher revs, makes sense in a way
