since reworking a cilinder head a short while ago, the engine is consuming oil. (DRAT).
at meduim & high RPM it can be smelled in the exhaust fumes and after 3 weeks of commuting at motorway speeds the oil is below minimum....
I took intense care of the head surfaces and fitted a pukker new gasket etc....but at the time I couldnt get the old valve stem oil seals off from the head!!!!
(I even tried to carefully prise them with a flatblade scredriver...but to no avail.)....so Im suspecting the oil consumption is due to failed valve seal(s)....
I want to have a go at replacing the seals again.....does anyone have any hints on removal & refitting?
