Alloy wheel help
Just bought an old 2000 micra s, it has horrible steels on it would these fit without rubing?
205/45/16 Tyres the wheels are 6.5j x16 h2 4x105
Willtheyfit.com
The overall diameter looks OK, but that's just the start.
-You'll need the new wheels' offset (or just assume it's close enough to the standard ones & hope for the best).
-Watch out for the centre bore. K11 hubs are 59.1. Wheels with smaller cb will need machining out to fit. Wheels with larger will need spigot rings to position themselves.
-You'll need PCD adapters as K11 is 4x100. Depending on design this may get you around the centre bore issue.
All this info is out there on the internet for you to teach yourself, as I have done. Start reading & you'll never stop!
Welcome - and happy Micra-ing!
damn, big wheels out there
6.5x16 can be difficult- width should be around 185/195. With profile 45/40 the tires will be quite expensive...
im using 175/50 @ 7x15
16's just look daft 15's are as big as you should go. Check out micrapro's blog. He's got it perfect with drop/wheel fit in my opinion. X
