Air Bag Warning Light + no horn or radio/computer contols
My 54 plate Micra has just had the EPS replaced. The power steering now works but the airbag warning light has now come on (flashing). Also the horn has stopped working and also the controls on the steering wheel that operate the radio/computer etc.
I have tried the key on key off proceedure that wasn't successful. I have also checked the fuses.
Any suggestions what it might be?
Sounds like the spiral cable (clock spring, squib, what ever you want call it) behind the steering wheel has been fitted incorrectly, it needs to be removed with the front wheels pointing straight and then refitted with them pointing straight, and whilst its off the centre of the spiral cable is not to be moved/rotated in ether direction. If this was not done at time of repair and the spiral cable as been fitted incorrectly, the spiral cable will become damaged and a new one required.
