H Hazara Apr 15, 2014 #1 Hello everyone, Can someone tell me where is this leak from? Engine or gearbox? How to fix it? Here is the video Regards
h701micra Deactivated Account Apr 16, 2014 #2 From the marks on the sump its either a gasket failure on the sump or a crank oil seal (behind the flywheel)
davyboy Apr 16, 2014 #3 Back of the rocker cover maybe ? then blowing back when driving. Check the nuts on the rocker cover first....bit of luck it could be that simple. Best of luck.
