masterbiker
5th gear next week will be putting petrol on test. I guess we will finaly find out if optimax is worth the premium price that it is.
Alienfish360 said:If you read Haynes manual, states that the engine is designed for use on 95 Octane fuel, but will also run with 98 octane but will give NO advantage over 95
masterbiker said:I posted this up so people would know that the deffernt petrols would be tested by 5th gear and might find it interesting, not if its good for any individual car.
Alienfish360 said:The only advantage is between petrol stations and supermarkets. Supermarkets get bottom of tanks and get put into one. Whereas petrol stations such as BP and Texaco get the good stuff from them. I'm led to believe
VladCFC said:The Car will only run better on a petrol with 98 Oct if the car has been tunned to run on the petrol. (i did chemistry as an AS)
This is because 98 has a lower Sparking point. A lesser spark will ignite the petrol where as 95 needs a higher spark. In theroy The 98 will give out more enjergy per litre due the higher octance number but the engine has been to set up for the petrol or you will see no difference
