15 x 8's -4 offset
CMF_frank2
they will protrude like this imo :eek:
(re-dished stock 5j 13 steelies @ zero offset and a 30mm spacer)
CMF_deNs
4DRFRK WROTE:
"still pretty keen to rock something like this
Rock something like this? <a href="">Haha...</a>
The most widely known offset calculator is <a href="http://www.1010tires.com/WheelOffsetCalculator.asp">this one</a>. From memory a 7-inch with +20 offset should bring it almost in line with the guards and from there you can use that as a base to compare it to what you want to do with it.
Frank you should've taken a complete side on pic ;) That image doesn't show how far they stick out very well - it's kind hard to gauge from that angle.
---dens
CMF_frank2
4DRFRK WROTE:
"ok so can anyone tell me the width and std offset on a 95 lx .... and yeah that's the offset calculator i was looking for thanks heaps.<BR>
<BR>
Daniel
the stock steelies are 5j 45mm, and the ally,s are 5 1/2j 38mm iirc daniel, but the fronts will prodrude about 10mm more than the rears (unless you have a fair amount of negative camber on the front)
there,s some pics of my misses,s car,s altered offsets here
http://www.micra.org.uk/showthread.php?t=22225&page=9
frank
