12" Wheels???
Squizza
Hi all,
Right wanting some wheels that fit, being looking high and low on here...
Do 12" wheels fit over the brakes and on a micra?
Cheers,
Luke
I think the overall consensus is that some fit and some don't. I think 12" alloys tend to have more room than 12" steels though, so your best bet would be to go with alloys imo.
I'ts been done, but I suspect that you;ll need low offset or spacing so the caliper fits in the largest part of the barrel.
I believe that those are 12" mini rims, banded and with micra 13" centres welded into the largest diameter inner section of the barrel.
aye 12" banded internally eh mark :)
Bought a set of 12" Ultralites... :D
Got the back two on no problem, I'm using logic and hopeful thinking 5mm spacers will correct the fronts out and make them fit nicely! :rolleyes:
I had 13" superlites on a 106, quite a different set up I know, but 5mm spacers on the fronts and a bit of shaving to the front caliper did the trick! I imagine you'll be fine, just gotta watch the shape of ultralights as the spokes can be a bit funky and rub bits.
Cheers Frank :p ...its actually quite close, there's a gentle narrowing as you get to the face of the alloy and that bit causes the brakes to not move at... all :oops:
I just had painted steelies with a colour coded lip and nuts on my 106 haha
Cheers for advice I'll keep observant! :)
Like your 'editing'... :p
Yeah that could be a Idea, I've being lucky though and found a place very local who specialise in modifying especially Jap Cars!
There very approachable and probably have a look for free so I'll just pop in tomorra... with the back 1/2 lower than the front1/2 of the car to start with :D
