1.4 K11 engine?
Type-R
how similiar is this to the cg13? is it a direct bolt in swap job?
If i am correct are the ecu's and wiring loom different. If so then does not sound feasible.
Am i correct in beleiving that the 1.4 bottom end is cg13 compatible?
the 1.4 bottom end might is cg13de head compatible. (i think)
but dropping a cga3de into a cg13 car is not easy due to the loom.
danm you i thought u were selling a 1.4 engine then :(
