W wrighty Ex. Club Member Sep 6, 2008 #1 Does the 1.4 almera engine fit in the k11 easy or do they need loads of work to make them go ..
frank Club Member Sep 6, 2008 #2 wrighty it,s a ga engine innit, same mission to fit for little gain :suspect:
OP OP W wrighty Ex. Club Member Sep 6, 2008 #3 yer its the ga ive got a ga13 for the turbo conversion but i have the chance of a rear ended almera thought with the turbo convesion the 1.4 may give a few extra horses
frank Club Member Sep 6, 2008 #4 wrighty you,ve got the complications of the longer ga block (longer than the cg), and it,s cast iron too
D Dewgel Buy & Sell Member Sep 7, 2008 #6 I can't really see there being much different between the 1.4 K11 CGA engine anyway, or is there something I'm missing?
C Corbs Ex. Club Member Sep 7, 2008 #9 1.4 engine is pants as standard, but 1.6 is pretty good (Used to have one in my almera SRi).
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 7, 2008 #10 GA16 is totally bomb proof. Fit one then turbo it. It will go like stink.
nexussteve The reason you're happy! Sep 7, 2008 #11 Is stink fast?? Coz it usually takes several seconds after I've dropped my guts before people leave the room...
NeX You're after my robot bee Club Member Sep 8, 2008 #12 nexussteve said: Is stink fast?? Coz it usually takes several seconds after I've dropped my guts before people leave the room... Click to expand... LMAO!
OP OP W wrighty Ex. Club Member Sep 8, 2008 #13 Ed whats involved with fitting the 1600 and would it need pistons when turboing im only looking to run around 7-9 psi
ollyc98 Ex. Club Member Sep 8, 2008 #14 I would've thought the cast iron block would be stronger and therefore smaller than the alloy block
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 8, 2008 #15 They are smaller(thinner), and so quite often not as heavy as you may at first think. Speak to others about the GA16 conversion, its not too bad but does take work.
OP OP W wrighty Ex. Club Member Sep 8, 2008 #16 Come on peeps what needs doing to fit the ga16 the work is no problem and has anyone turboed one yet
Ed Fusion Motorsport MSC Founder Official MSC Trader Sep 8, 2008 #17 there is loads bout this on the site, do a search.
squarepants Ex. Club Member Sep 8, 2008 #18 nexussteve said: Is stink fast?? Coz it usually takes several seconds after I've dropped my guts before people leave the room... Click to expand... lol sigged
Q quickdraw Ex. Club Member Sep 13, 2008 #20 the GA engine isn't that bad to fit actually, its just making sure you mount it properly otherwise you get clearance issues! good solid engines, as Ed said, turboed ones are pretty nifty..
squarepants Ex. Club Member Sep 13, 2008 #21 but the ga14 wont be as fast as a cg13. for one its havier. i would ither go cg13 or ga16.
