1.0 i want to put a bigger engine in, any help?
i have a s reg k11 1.0, but i want to put a bigger engine in.
i want more power but want to try and keep the costs down, what engin and other parts would i need to do this?
if any one could give me a few pointers that would be much appreciated.
thank you andy
Well the CG13 1.3l engine is the only thing which is a straight fit
Other things to improve performance can be exhaust, cams, re-map, manifold.
the 1.3 gives you 75bhp, rather than the 54?bhp of the 1.0.
Add the manifold along with a decent filter/exhaust set up and you'd be looking at around 100bhp.
Cams and a remap would take you to 110-120ish?
Your looking at near enough double the standard 1.0 power.
Depends how deep your pockets are ;)
Get a CA13DE Micra engine, and the ECU for it.
if you mean the CGA3de engine, it wont fit because the loom is different, you have to sort out the coil packs, unless you get an import engine like me which is 1.4 but uses a dizzy still ;)
Yeh, sorry, haha. So used to saying GA16DE for the NX. My baddd :unclesam:
