gearboxes
The best gear box to use is the 1.0 gear box from a 2000 spec Micra with 14" wheels, this has a final drive ratio of 4.4?? : 1 instead of the standard 3.7??:1 final drive. You need the back plate as the starter motor bolts from the other side on the late K11. This gear box uses the same drive shafts as the 1.3 micra.
i already have that box :p i just want to use it with a 1.4, and i want to know how much i can tune it up before the box will play up.
Ne ideas on how much bhp it can take? thanks!
