wtb: throttle body adaptor
CMF_barney
hey all,
Was wondering if anyone has a throttle body adaptor to bolt a sr20 throttle body onto a std intake manifold. I saw a thread where there was a group buy on some custom ones a while ago.
Even if someone has one that i can borrow to measure up.
Thought i would ask before i start making my own one up.
Cheers, Brad.
CMF_Danvillan
What mods have you done?
I think the biggest restriction comes from the intake manifold. On an N/A motor surely a ga16 TB would suffice (which is straight bolt on). If you're boosting then a custom intake manifold to take a sr20 would be the go.
I'm not sure but may need a remap to run the sr20 tps plus there is no MAF sensor in the sr20 tb so you have to mount a remote MAF sensor in the intake somewhere, plus the loss of ICV.
More drama than it's worth IMO.
Just seems like a big job to make an adaptor plate for little (if any) reward.
CMF_barney
Ive got a aftermrket ecu which is using a map sensor, so no need for a afm. Plus i have a spare sr20 throttle body.
The engine is fairly std, about to install extractors and make a new exhaust to go with a another motor which has had the head decked. So nothing to crazy.
Once it all goes in i will tune it on 100 octane united pulp.
CMF_frank2
mine went well with an SR20 t/b on brad (and QG injectors/better inlet cam/modded exhaust)
in fact i,ve only so far since shaved .2 secs from my 1/4 mile time with various turbo,s !
my adapter retains the 2 front bolt positions, and the plate is simply sandwiched between the t/b and mani
CMF_Danvillan
If you got an after market computer w/ MAP sensor then it won't be too much of a drama.
Still dont think it will be much better than a ga16 TB.
If your going to run a hi-comp motor why don't you go for quad TB? then you can piss the intake manifold off.
Just a thought.
