wobbly pully?
hi
while checking over my engine, i noticed that one of the pullys wobbles while the engine is runnin, its the one below the water pump i think. my car doesnt ave power steering. what does the pully drive, nd how wud i go about fixing it, as it makes a noise.
i'll try to take some pics in the morning, but its hard to photograph
thanks
steve
Need a pic really i guess you mean the crankshaft pulley..or the alternator pulley..which is more likely to make a noise..
yer i wud say that'll be what it is, ive tryed photographing it, but cause its dark u cnt really see it, al try again in the mornin, nd c if a cn get a better pic, if thats what it is, is it bad tht it wobbles, nd how cud i fix it?
I think yours is the first one?
its the pully that is directly under the waterpump. the belt goes from the crank, to the waterpump, around this pully then bck to the crank
yes its is the 1st pic, on tht one sjackson, thanks, its jus an idle pully then. like frank said! how wud i go about fixing it?
bit critical seeing its the water pump belt
theirs a nut on mine directly beneath idler pulley that tightens or loosens the belt via pully
nut is reached from beneath car or above -if you know what you doing
