maxed out micra
Will It Work On A 1l
I dont see much point in them, on a Micra, thats a bit silly...
yes it will work
I hear they work better with a turbo?
I think it more boils down to the fact that (in the UK at least) flamer kits are illegal.
lmao could imagine passing an MOT would be fun on that setup
pfft, good one!Right back to work
There wont ever be a time on a Micra (K11) when there will be enough unburnt fuel to do that, even without a cat. When you throttle off the ecu cuts fuel, when you hit the rev limit the ecu cuts fuel first, so there wont ever be enough in the exhaust...
For that reson youll only get an artifical one working..
Some flamer kits I know of spit the flame out everytime you change gear, I followed a 200SX with one a couple of months ago...
raceworx's & richmicratwista's micra's spit flames out every time you let off at high revs, both have de-cats and janspeed manifolds.
It was Ed's mates car, and it was a stock CA18DET with twin exhausts lolchances are it was just well modded dude
and on a serious note, a modded 1.3 K11 with manifold full zost inc manifold n decat will flame, mine did...
James, some highly tuned cars spit flames when changing gear normally, its not a kit its just what happens... watch the rally cars they do the same...
why?
Correct me if I'm wrong but they get the flames because of their anti-lag systems, that are needed on the turbo powered rally cars as rally cars aren't allowed dump valves or re-circ valves.
my modified k11 i dont think has EVER spit flames since the janspeed manifold and de-cat exhaust was put on??
any explanation for mine not doing it?
dont get me wrong...im very pleased that mine doesnt spit flames evrytime i change gear but what would be the difference??
napster
yours probably has the right air/fuel mix lol
thanks
but would that be the only reason? would it be anything todo with "a hole in the exhaust somehwere"? or that wouldnt effect it?
im just enquiring because its interested me now
na, i'm pretty sure it would be down to the mix. basically you need unburnt fuel to catch fire inside your exhaust. to do that your engine needs to be spitting unburnt fuel which will be an issue with the mix or the timing, and then there needs to be something like some glowing embers in the exhaust or something like that to ignite it. so the fact that yours isn't flaming is a good sign that everything it running fine
Its not that simple but in any case you dont need to worry either way.
napster
Why do you say 1.0 micras run rich?
i think he means once they have a manifold and decat
