A andy_con Club Member (Trial) Feb 14, 2010 #1 the passenger side washer jets are blocked. anyone know part number for a new one and a rough cost? are they easy to fit, do the pipes just pull off and push on? all info welcome thanks
K k11micra Feb 14, 2010 #2 They are fairly esay to take out, but if you knoy someone with a compressor in their garage, then get them to use an air gun to blow from the jet back to the resivoir
OP OP A andy_con Club Member (Trial) Feb 14, 2010 #4 so you mean dont take it off, just try getting the #### out first?
ferritboy Ex. Club Member Feb 15, 2010 #5 Try poking a needle or pin down the hole to unblock it or take it apart and blow hard down the pipes and washer jet...
L lucasmax Feb 16, 2010 #7 sp13rsy said: i just replaced mine with the new wide mist ones from halfords Click to expand... they the ones with the led's in?
sp13rsy Feb 16, 2010 #8 no just turns the spray into a mist and covers the whole window screen would upload a photo but cant seem to get it to work for me
OP OP A andy_con Club Member (Trial) Feb 16, 2010 #9 ok thanks guys will see what i can do. so do the pipes just push on and off?
Helloween Feb 17, 2010 #10 yes mate, just pull off the pipes carefully and fit new jets the push back on firmly... 1 min job each side. mine havent been working for 2 years and still pases the MOT dont ask !!! but will need to change mine anyway.. J
