Using my spare wheel...
Tom Messy
My wheels are 14" and my spare is 13". Is it ok to use the spare as it's smaller? I think the tyre is fatter though...
Tom
better to keep different size wheels on the rear as then it doesnt ###### up the diff.
with that size difference though, i should think you will be fine!
There is a rolling radius calculator and visual simulation on the Carbibles website. If you enter the size of your 14" and your 13" tyre you will probably find that they are pretty much the same outside diameter.
Yes I was thinking about spraying the steelies silver, but lacking a seperate set the only option is one by one! *yawns!*
Yes that was my thought. Shouldn't be too much different
Tom
