CMF_Danvillan
» CMF MemberSort of trying to figure out how this will be set up for a turbo setup.
I believe the PCV is a one way valve (correct me if I'm wrong) so shouldn't be effected by the boost but it wont be releasing crankcase pressure if plumbed to the intake manifold.
I was thinking the breather can either go to an oil catch can or pre-turbo , rebuilt motor shouldn't have too much blow-by.
Does going pre turbo suffice as a vacuum source?
So basically if someone has a clue I want to know the best setup to achieve the following:
1. Keep emissions legal
2. Allow the crank case pressure to breath while under boost.
3. stop oil entering the intake
4. Any other consideration I need to consider?
