turbo oil feeds
Broony
i have a T2 turbo which has been refurbed and was very cheap just so i could see where i want to go power wise and until i can afford a good/new condition t25.
just woundering if anyone could tell me which is the oil feed and oil drain and will the positioning affect it?
Is the above the oil feed??
Is the above the oil return??
If so as you can see how it sits will this affect how its lined up as the oil feed if its correct is at the bottom??
Can this be changed/moved??
Does that not have water cooling also?
I don't think that it will matter what way up you mount it as the return is gravity-fed, although I'm sure Ed will come on soon and post the correct answer!
Craig
you are correct on the oild feed an returns.
The return has to be facing the ground maximum degree from the ground i would say nor more then 30-40%
you can rotate it by undoign the bolts and rotating the housings, easy to do and the turbo looks new/refurbed so should be very easy.
