tunning question
A
ash 80
I need some advice on where to go next with my engine i already have
k&n air fillter,janspeed manifold,fse boost valve,powerflow de-cat exhaust.
what would be the next step i was thinking cam kit or throttle body anybody in the same position?
What engine you got, 1.3? If so then piggy-back ECU, maybe GA16 tb and injectors and a set of cams. A lightened flywheel will also see you good.
If you have 1l, 1.3 cams are the next step.
No, you need to either twist an injector round, or space the throttle cable bracket out with a few washers
and you need to blank off the idel speed controll valve as it wont fit with it on! also its a pointless mod and made no difference to my car whatsoever apart from make it run crappy and overfuel!
i was going 2 put the bigger Tb on me car... but decided agisnt it....
does ur fse boost valve make any diff?
FSE can be used to fine tune emissions for MOT time, the 1.6 tb is a bad modification imo, once i took it off i found i had better running. If you could put on a 1.6 TB and use a CG13 ECU with a piggy back if thats possible would be much better,
i kinda in the same pos.... was looking into getting a fuel controller.... not sure tho... hmmm will have 2 think about it
