1.3 fuel rail/injectors on a 1.0 - any gains at all?
Daniel
I WILL be back...
Ok people, need a bit of advice here. Recently managed to source myself a 1.3 fuel rail with 1.3 injectors, and a Walbro fuel pressure regulator. Will there be any noticable gains in getting these fitted?
I also have, in the way of engine modifications - 4-1 manifold (de-cat, with Lambda sensor), Janspeed de-cat pipe, straight through backbox, heat proof exhaust wrap from manifold to backbox, K&N induction kit, Pipercross cold air feed, and NGK iridium spark plugs with NGK HT leads.
What gains will I be able to expect, and will they be noticable? And will I see more gains if I get an ECU remap - and if so, where can I get this done?
Would appreciate any help here at all (Y)
OP
OP
Daniel
Daniel
I WILL be back...
You could be right there. But it didn't look like the same material as my stock downpipe though? Even it is, will I still gain something? I can't waste all that effort for nothing!
frank
its a nice looking mani dan, but it needs connecting to someting like a peter lloyd system really, all that free flow will then hit the skinny 31mm dia bottleneck near the cat flange there fwn
OP
OP
Daniel
Daniel
I WILL be back...
Yeah, that's kind of what my thinking was. I might just fit this one and see what it's like, fit all my other parts as well. If I notice any difference, I'll leave it (unless it ends up slower). Might invest in some CG13 cams as well. Either way, it's bound to do something :laugh:
frank
that mani and a 1.3 inlet cam will give a noticable gain, sure :)
OP
OP
Daniel
Daniel
I WILL be back...
Cool :grinning:. I guess it's just a case of fitting all the parts I've got now, seeing if there's any gains, then maybe going for the 1.3 cams, and whatever else I can get cheaply. I'm sure I'll notice something before I get the cams though. I hope :laugh:
