timing
What does the et mean?
Give the engine size, year and ignition system and I'll tell you.
The engine code is ma10et its an 85 march turbo (not superturbo)its a one litre 8 valve turbo.I think its bosch ignition with eccs.Thanks for your reply.
Its all eccs. Bosch usually supply alot of parts however.. However it should be set to 15degrees BTDC same as all other Nissan eccs.
the ma12 auto is 2* BTDC from what I can tell, don't know if that helps? what is eccs?
ECCS is Nissans ECU system. You dont have it, so yours is totally different.
Thanks for your help.
