Throttle Body
M
MrRee
Does this common fault affect all years or did Nissan sort it out for the later cars.
AND, what exactly is the fault? There is a DIY fix I understand? What is it?
It has been noted as a common problem for k11 micras to suffer from some dry solder joints inside the throttle body's electrical compartment. This can make the car have terrible fuel consumption, jerky/rough idle, loss of low to mid range power and intermittent stalling.
If your micra is suffering from these symptoms, we strongly recommend you download and follow these instructions as this has been proven to solve problems on many peoples' micras.
http://www.micra.com.au/technical-articles/cg13de-throttle-body-resoldering-guide.pdf
I am in the process of making a guide to tell all and everything about this problem, will be uploading it on thursday night!
