right now i have had this problem for a while, the n/s headlight keeps loosing dipped headlight,
ie when dipped is selected the o/s will come on fine but the n/s will remain on sidelight.
obviously this is annoying for more than one reason. i know what he problem is but i cant seem to fix it, the fuse in the box under the engine bay keep coriding hence the connection is broken and the light stops functioning correctly. i have replaced it a number of times now and it is getting annoying. well it went again the other week and i replaced it as per usual and now the fuse did not even correct the problem.
so i can only assume that the corrosion is too much/has gone too far, blocking conection etc.
is there anyway of getting rid of this problem. an oil or grease designed for such a problem? can you just chip the corrosion away or what?
im being causious seen as its an electrical problem and especially after the recent fire that took place in mr grassies engine bay
any advise welcome and much appriciated
