Spares to be almost breakdown-proof!
Hi there. I have two K11s, a 2001 1.0 and a 1999 1.3 which i am probably breaking for spares. I want to carry enough spares to avoid total breakdowns. Please would you suggest what I might need and what I can do without?
I am assuming that it will struggle on without temp sensors and throttle position, but it must have a working MAF sensor and flywheel trigger/sensor. A spare fuel pump would be sensible I suppose. And obvious things like alternatir drive belt and sundry fuses, bulbs and bits of wire.
Have I missed anything, please? MTIA
wont hurt having this in amongst your kit
Never used plugs in car tyres! I usually carry a spare (2 in snowy weather, with snow chains pre-tensioned!). I used plugs on motorbike tyres, though. Very effective:)
Am I right that it should struggle on with only MAF and crank sensors, then? Throttle position, temp, vacuum and stuff can wait until I get home? This gets better :)
Is it just the one fuel pump? And I guess a spare pressure regulator woyldn't do any harm, although I'm guessing they go wrong slowly...
