Simple way to wire in fog light switch
B210Bandit
Right, after buggering around for an hour trying to get the fog light to work I'm going to stick in a simple switch and run wires to the rear. What's the best way to take a feed off the loom? It's only for the mot. Who the hell needs these things anyway.
Cigarette lighter is normally a reliable power source, you can take take it from the side lights so it only comes on when the lights are on which is what K10s do (well my super s does).
Thanks. Ended up taking it from the side lights at the rear so it is not compliant I.e. only soon if lights are on. No relay but the fuse seems to hold up.
