CMF_queazocotal
» CMF MemberA source of inefficiency at low throttle settings is
dragging the air through the nearly closed throttle.
If the supercharger were connected to a variable gearbox,
then in principle could it make low speed more efficient?
Intead of the energy used in dragging the air through the throttle just being used to heat the air through turbulence, it is partially recycled into the engine through the drive pulley.
