Hi All, What should I do about servicing my 1998 k11, the mileage stands at 71100 the Haynes manual does state after 10years check SRS but my k11 doesn’t have that anyway. And the original owner did all his own repairs so I don’t have any service history or records? I have just had the passenger side rear sill wielded also replaced some bulbs. And I cut off part of the plastic wheel arch covers / the part I cut off was the section running down from the spring to the rear of the front tyres, that was because, on removing them it I found a lot of mud had collected behind them from the waste gluey. The last owner did say that he replaced the clutch but I don’t know when.
On a smaller note I have just tried & tested a method of removing condensation from the inside of the car without the a/c or heating on, try shaving foam or any product with lanolin in them. Just wipe over the glass on the inside of the car but still being able to see out of the windows and remove any leftover foam. And you’ll see the results straight way without using the heater or A/C when you use the car. Please tell me if it works for you!
Yours Peter0003
Yours Peter0003
