Rev Counter
paul_k10_Lx
Deactivated Account
i have a 1.2 lx however it has the ecc stuff on it so a different ignition system where do i connect the rev counter too ?
it still works on the same principal as a normal 1.2, its still got a coil on the side of the engine bay, there should be wires from it, all you will have to find out is whats the + and whats the - and the tap into the + and bring it to youre rev counter
You have to connect the rev counter to the coil, as it is connected on the following picture (to the white cable with a red stripe)... remember that if you are using the whole gauges (i dont know if that is the right word) from the SuperS you have to connect the rev counter thru the 2.2kOhm resistor... have phun ;)
wooooo dont connect it to +ve!!! its Negative you conect it to!! dont wanna start any in car BBQ's going!!
lawina said:
are you saying that i am wrong with the solution?
think he was talking to ohc turbo,,about +wire is wrong,,it should be the -wire to tap into :D
