Rev counter not moving past 5500rpm
Hi guys quick question, I recently put the sr clocks in my 1.0L Micra but it doesn't rev past 5500rpm. Is there an adjuster that you can set the limit to? I'm new to this mod and don't know much about it. Thanks for any answers in advance :)
I'd suspect your tacho isn't quite accurate as there's a ECU enforced cut @ 6400 IIRC, it's able to be removed either via Nistune or Fusion might be able to do it or you can put some tape over a hole in the dizzy but as far as I remember it also disables another useful feature, just I can't remember what it was....
