C crutts Feb 19, 2011 #1 How easy is it to remove the pedal box from a micra? Can it be done with the dash in? Ta Joe
frank Club Member Feb 19, 2011 #2 clutch pedal is a separate assy joe (no doubt the brake pedal too) and pretty awkward to access with the dash in Attachments SDC11475.JPG 275.6 KB · Views: 331
OP OP C crutts Feb 21, 2011 #3 Cheers Frank. I am going to make myself a bias pedal box and dont want to start taking bits off I dont need too. Ta Joe
pollyp Club Member Feb 22, 2011 #5 the brake pedal bracket is bolted to the brake servo through the bulkhead with 4 nuts (access under dash) the clutch pedal bracket is bolted to the bulkhead with 2 nuts (access from engine side) and 1 at the top of the bracket (access under dash)
