The Micra gearbox( bubble micra) has an uprated gearbox on later models , it is visually different , and the clutch is different , also the drive shafts are probably different, so you will have no problem accidently fitting one LOL.
The internals of the " big" gearbox are totally different to the earlier K11 ( and the K10 ) "Small gear box" and nothing interchanges , the Almera gear box is similar to the "big" Bubble Micra gearbox , but I do not know the interchangability yet.
And Davon if you are an Autograsser in NASA class one , then re read your rule book LOL.
ps . I used the description " big " and "small " because there is a noticable difference in their weights.
