just bought a 1.4 year 2000....car came with no codes for immobiliser, radio etc, no key code or PIN no.....i'm not worried about the radio as i'll replace it with a CD/radio, but do i need the immobiliser code for any reason (e.g. when disconnecting the battery) and do i need key codes etc? (i have just got a spare NATS key cut at a cost of £40!)
also, the engine management light has been disabled (it doesn't come on when ignition is switched on) and service records show that a fault code P0171 has been stored, probably oxygen sensor......i guess i need to replace or reconnect management light and and get sensor and possibly air flow meter replaced?
i must say i'm really impressed with the car, its the youngest we've ever owned!
but why did they go for the complicated rear axle set-up, rather than the usual trailing beam arrangement?
finally, any recommendation for a suitable central locking upgrade kit would be welcome (its a 3 door)
Adrian
Adrian
