NATS and Door Cards
TriNode
This weekend looks like the time I'll be fitting my electric windows and alarm, so I've 2 questions:
1) can NATS be disabled? (the new alarm will imobilise and I wanna have a play with the remote start, nats causes issues obviously)
1b) if not how much to get a third key, and have it programmed? (I assume the ECU can have at least 3 keys registered) (don't ask :))
2) What's the proper way to remove the door cards, I figure remove the handle, and the tray at the bottom, how is the winder removed? I see there's a clip but I'm unsure on removing it, then wind the window down, how is the rubber seal best removed? I've read the card itself is pulled away then when all unclipped lifted up and out.
Cheers,
Ant
