micra turbo kit has be sold
Thinking off something Diffrent and been busy for months stripping all the car down, and wires from Inside and engine looms come off, needs welding under stills and front chaiss,
looks heavy and lots off wires needs cuttin and replacing,
Getting down on the manual and read most of the engine ecu controls engine, the ign has permanent live and ign live, the starter motor has ground from battery, fuel pump is by ecu, am only keeping the interior loom only, and the engine loom is a Diffrent story
looms done after digging out all the wires left the fuel pump out and ign live and ign wire so Sunday gona plug all this in car
u don't need the inteoir tested as it was working from before, and stock look I only took and traced 2 wires from it,
Wires all fitted inteoier and pulled 4 main wires out on the loom which is live wire, ignition wire, fuel pump relay wire, and coolant wire, my aim is 1 year on this project, need a engine crane before I start
