HKS Kyusyu turbo kit
CMF_STARTLE
I was just wondering if anyone here has a HKS kyusyu turbo kit on their Micra. HKS Kyusyu also make coil overs for the Micra but I would think that tracking down these parts would be very difficult. Any ideas?
Owner: Masahiko Maeda.
Stage: Street.
Installed capacity: 200ps.
Largest torque: 22kgm.
Engine: HKS Kyushu turbo kit, intercooler and head gasket, 720 cc INJ, TOPFUEL one off delivery pipe, Tomei camshaft, head cover paint, TOPFUEL one off oil cooler & one off turbo muffler, apex ECV, Bu Ritz fuel pump.
Drive system: HKS Kyushu twin plate clutch.
Tire: F/DNA-GP 175/50/15 R/DNA-GP 175/50/15.
In addition: HKS Kyushu revolution damper, lateral rod, NEKO AF700, RECARO SP-JJ franc car.
CMF_makes
Hi Startle,
The HKS turbo kit for the CG13DE motor can be supplied to Australians by www.perfectrun.com.au
This is a complete kit which includes a T2 turbo, exhaust manifold, intake filter, pipes, clips etc. This kit doesn't include bigger injectors, an intercooler, ECU etc... It's designed to be a simple kit to bolt on to a standard car without having to change anything else... max boost would be around 4-5psi which apparently provides about 30% extra performance over standard... ?
The kit is actually intended for the Japanese market only Nissan "Cube" but would probably work on a micra as well ?.
Perfectrun said the following ;
"Please note that HKS Bolt-on Turbo Kit (Item Code: 1101-RN001) is for Z10 Cube and HKS is not sure if you can use it on your K11 March or not...."
I got a quote from them a few months ago, at the time the cost was about $3650 including delivery. This is much cheaper that CAPA.com.au who are asking over $5000 for the same thing.
I hope this helps...
