ok here goes
a red key, require the car to be put on a machine and the ecu takes the key chip number and hey presto it works.
a blue chip key requires a code ie from nissan and then coded to the car
i hope this has helped so far keep with me on this
the nats system is a good system, once keys are programmed to a car that is it (they can be reprogrammed) the system is set, if a car is then started with a key that is not coded to the car it will fail to start.
are you still with me here
the mod
if you get a new key cut and cant/wont pay for a recode you can remove panels around the steering wheel and look at the barrel you will see a ring of plastic this is the pick up for nats, ie detect key chip, remove and tape you old key to it and use the new key that you got cut. and hey presto it works.
now if you place a non coded key in the ignition at any point a car will fail to start. if the mod hasnt been done see above.
i hope this helps you with this request. if it was me and if i didnt av the tech machine (i can get hold of this machine that nissan uses) (Y) i would walk away you dont know what state the engine is in.
